Load meter off the index table
FlashPro Manager software
rdxturbo
Post by rdxturbo »
The load meter goes off the table and I can't add more columns to the 7 on the table. This happens to all RDX calibrations.
Is this normal? How are we supposed to tune the area off the load index table?
Re: Load meter off the index table
Can you please post the calibration in question and let us know the year of the vehicle.
rdxturbo
Post by rdxturbo »
I have a 2010 RDX.
This seems to be the issue with all calibrations for the 1G RDX in the Hondata database, regardless of year, except the carb compliant ones since those don't have any ignition/fuel/cam tables.
Trying to add or remove columns just moves the columns over, but there are still 7 columns max.
Go to the options menu and make sure you have it set to show all the boost tables.
rdxturbo
Post by rdxturbo »
That solved the problem. Thank you.
