AFR for all gears at WOT
4d7
Post by 4d7 »
Hello,
I wondering if AFR should be consistent at WOT through all gears.
For example if 13.1 afr is achieved at 3rd WOT, should all the other gears be at 13.1 as well?
The reason I am asking is because my 1,2 gears are leaner and 4-5-6 are richer than 3rd gear WOT.
Re: AFR for all gears at WOT
What vehicle are you referring to?
4d7
Post by 4d7 »
2011 Civic SI
4d7
Post by 4d7 »
With a hybrid racing intake on a speed density map.
What readings are you seeing?
Can you post your calibration and a datalog showing this?
4d7
Post by 4d7 »
Sorry for the late post, the weather has been too cold the past few days to datalog.
4d7
Post by 4d7 »
Hello,
Just wondering if you’ve had time to take a look at my catalog.
It looks completely normal.
The engine ramps up a lot quicker in lower gears and may show slightly leaner, but since they are not in this state long it is not an issue.
4d7
Post by 4d7 »
Sweet thanks for reviewing you guys are awesome
