Chipped PR3
7rrivera7
Chipped PR3
Post by 7rrivera7 »
I have a chipped PR3 I'd like to use for Hondata. Does the stock ROM have to be installed or can I leave the current Spoon chip installed? Does Hondata provide its own chip in which case my question is moot?
QUICKSILVER RACING
Post by QUICKSILVER RACING »
Why would you wat to buy Hondata if you don't want to alter your fuel and timing.
HONDATA official and sole Distributor in the Philippines.
http://quicksilver.4t.com
+639178954747
7rrivera7
Post by 7rrivera7 »
That's the whole point - can I still change everything even though there isn't an OEM chip in the socket?
AndyE
Post by AndyE »
If you have a Spoon-chipped ECU and want to get a Hondata system, you're going to be removing the Spoon EPROM and replacing it with a custom EPROM with the Hondata program on it. This custom EPROM is provided by your dealer, or can be programmed yourself if you purchase a stage 4b or an S200 system with ROM editor.
-Andy
'99 EBP Si
S200 w/everything|12psi JRSC|Heatshield
AEM CAI|Kamikaze headers
Custom (quiet) 2.5" exhaust
Quaife LSD|JUN 9lb flywheel|ACT XTSS clutch
Eibach Pro-Kit/KYB AGX
Full polyurethane bushings/mounts
OZ 16x7 Superleggera + Sumi HTR Z II
QUICKSILVER RACING
7rrivera7 wrote:That's the whole point - can I still change everything even though there isn't an OEM chip in the socket?
I didn't get your question. But you got your answer rom ANDYE. You will use a Hondata ROM to alter fuel and timing.
+639178954747
