MAP scale when logging is weird
DaX
Post by DaX »
I'm using SManager 2.7.5.0. Datalog was taken on 20-Nov-2019, so I'm not sure if that was before or after I updated to the latest SManager and I'm not sure if it would look like this in the previous version. Anyhow, the scale for MAP is from zero to a huge number (10^13!!) on the side of my logs, but the cursor shows the correct MAP value. If I go to Options > Sensors > MAP, the unit is set to "/psi and the range is from -29.92" minimum up to 30 psi maximum. It's not a big deal, but I just wanted to point it out to see if it's a bug or if I may have something set up wrong.
crluver123
Re: MAP scale when logging is weird
Post by crluver123 »
Go to OPTIONS at the top, click SENSORS, select map sensor, check the min and max values
DaX
Post by DaX »
Yep, I made sure that was set up correctly - 2nd to last sentence of the original post.
-29.92" minimum
30 psi maximum
I'll try to do a fresh log in the next few days and report back.
If you go to the sensor list and double click the MAP what settings to you have it set to there?
DaX
Post by DaX »
It is just a rounding error in the display and will have no effect on any readings or tuning. We will correct this in the next release.
DaX
Post by DaX »
Sounds good, Spunkster.
