Turbo Boost Issue Question
fk8newb
Post by fk8newb »
I have a question related to the upgrade of a new turbo and a friend that is wanting to swap over from Ktuner to Hondata (Only if this is the answer to the following) based on the items attached (A screen shot of a menu in Hondatas Plaform for FK8's related to our answer, and a Data Log from Kutner suggestive of the frames skipping when he is WOT and boost is not being regulated) he has trouble shot the "Emissions System Problem" aka P0106 Barometric/Manifold Absolute Pressure. Through means of leak test, sensor replacement and now only lacking what he are asking that if he was to swap and select the option as shown in the attached, does that fix this hard fault if that is what it is or not? Because as he mentions he has heard that Ktuner is limited on the Boost Curve and such.
Scratch the attached .MP4 or .avi arent allowed to be attached here, so we attached the original data log in K tuner and got the same error
Re: Turbo Boost Issue Question
I don't understand what you are asking. Are you using FlashPro? Do you get the P0106 error using FlashPro?
fk8newb
Post by fk8newb »
Are you using FlashPro? - Me, Yes....Him
Do you get the P0106 error using FlashPro? - No, He does with Ktuner.
Which is my question, He is wondering after all the trouble shooting we have done I have suggested that it could be the related lack of table option in Ktuner presently. I recommended that it could be the menu shown in one of the screen shots that could fix that CEL and I was asking you If you could confirm this being the fact of the matter? So in short, ---> Is the error he is having related to, and solved by if he was to switch from Ktuner to Hondata the solution with that error of the MAP sensor P0106 related to and fix to the Over boost option?
Return the ECU to stock. If it still gets the error then it is the vehicle.
