Air fuel mixture
Air fuel mixture
Is 12.24 to 1 to Rich or is it fine to run it like that cause I thought 13.5 - 15 to 1 is the proper air fuel ratio?
- CalibratEd
- Contact:
Re: Air fuel mixture
It depends on the Setup of your vehicle and under what load you are seeing this AFR.
Instagram: calibrated.tuning
It was running at 12.24 at idle and when I would get up in the room it would get Dow in the 11 range I just don't wanna hurt the engine
O and it's a b20v NA setup
Oman1991 wrote: Thu Apr 09, 2020 8:23 pm It was running at 12.24 at idle and when I would get up in the rpm it would get down in the 11 range I just don't wanna hurt the engine
civic EK sir
it should be in 15-14.7 idle and low load
civic EK sir
if you run 12 -11 your spark plug will not last +you wash-off that protective layer of oil in cylinders.
I recommend you check the spark plug to see the fuel mixture sometime one injector can cause your AF to go to12-11.
K ya it's running at 14.2-15 at idle
It's was just reading wrong
