Error code 15 Ignition output
300whpcrx
Re: Error code 15 Ignition output
Post by 300whpcrx »
Spunkster wrote: Tue Oct 10, 2017 4:11 pm look at the sticker that should be on the gray plug that can be seen with the lid off.
I can see a spot where adhesive once was but no sticker. ;(
300whpcrx
Post by 300whpcrx »
Here is a pic of the inside.
You really need to try this ECU in a known working vehicle. This will help you determine if it is related to your vehicle or if it is the ECU.
300whpcrx
Post by 300whpcrx »
I wish I knew another person in the state with an integra.
Try searching local forums, Facebook or any performance shops in your area. They should be able to help you find someone locally to test this with.
terryburns
Post by terryburns »
I am having this same issue on my crx. Car does not start at all. It’s running a p06 and all work on it was done by humble performance. It just throws error 15 in hondata. I changed out switch and still the same results. HELP!
Have you discussed this issue with Humble performance?
