Part Throttle Hesitation?
Civic 2016+ 1.5 Turbo
yos025
Re: Part Throttle Hesitation?
Post by yos025 »
Here you go. Zoom in from 2 mins 36 secs to 2 mins and 43. This is when I start accelerating and at minute 2 and 41 secs you can see how the revs start going up and down up and down as I was stepping on the pedal. I quickly stop hitting the gas knowing that something was wrong. the I tried again at minute 3 and 20 seconds. same result fell the car jerking up and down just like the revs go up and down on the graph. at this point I turn on main cruise to cancel traction control.
But me being me, after a while driving decided to give it another try. eventually I gave up and just left the main cruise control on and came back home and re did the calibration with traction off.So you know, I am driving a Hatchback Sport 2020 on a base 6psi with Mishimoto intake( boost and Traction control on the mods)
Please update your software version and reload the calibration.
yos025
Post by yos025 »
Hondata wrote: Thu Jul 16, 2020 5:40 pm Please update your software version and reload the calibration.
I just Did and went out for a quick ride to test.
I pushed it a little to see if I got the issue I got before and I did not. I am posting the my calibration and Datalog for you guys to see.
I see a big difference in the TC retard It only went up as high as 5 degrees compare to when I had the issue that was constantly up and down and up to 15 degrees also it did not activate as much as before. Anyhow see the logs
Thank You again... You guys are constantly listening to us. I did the right thing investing in Hondata instead of other tuners... :-)
