my calibration
Civic 2016+ 1.5 Turbo
tcr1
my calibration
Post by tcr1 »
i have install a exhaust and i would like to know if all is correct.
test#1.fpdl
Re: my calibration
The knock control is low which is good.
But the fuel trims are quite negative. Do you have an intake?
tcr1
Re: my calibration
Post by tcr1 »
Yes I have a PRL Short Ram intake Race , with the exhaust I have less torque .
I will post another recording .
+ 6 PSI
tcr1
Re: my calibration
Post by tcr1 »
I made another recording .
effectively ,the accelerator to the floor and I release slowly and I feel more power.
Do you want to see the data at + 9 PSI.
test#2.fpdl
tcr1
Re: my calibration
Post by tcr1 »
I made a recording : base map civic si 2020 and + 9 psi .
You will see the differences VS + 6 psi .
base map-si.2020.fpdl
+9 psi.fpdl
thanks
Re: my calibration
Your fuel trims are averaging -10%. You need to tune the AFM table because the intake has a different air flow past the AFM than stock.
tcr1
Re: my calibration
Post by tcr1 »
is this on all calibrations i have posted ?
how i do that ?
tcr1
Re: my calibration
Post by tcr1 »
by selecting AMF calibration for PRL cold air intake is not enough .
is there anyone doing it online ?
Re: my calibration
What intake are you using - in one place you say SRI and another CAI?
What MAF housing are you using - street or race?
What calibration are you using?
tcr1
Re: my calibration
Post by tcr1 »
SRI
Race
+ 9 psi via sport button and FTS
this morning I activated the o2 sensor, to see if the motor would compensate.
test + 9 psi seulement sport.fpdl
tcr1
Re: my calibration
Post by tcr1 »
I had forgotten , Invidia Catted exhaust .
Re: my calibration
You're using a race AFM housing but the calibration you're using is for a AFM that reads the same as stock. That is the problem.
tcr1
Re: my calibration
Post by tcr1 »
which one should I choose
tcr1
Re: my calibration
Post by tcr1 »
I put the stock back and I send you the data
tcr1
Re: my calibration
Post by tcr1 »
intake stock
exhaust catted
+ 9 psi FTP mode sports
intake stock + 9 psi mmode sport FTP.fpdl
