FlashPro Requests
FlashPro Manager software
KT7788
Re: FlashPro Requests
Post by KT7788 »
Request ignition parameters
- New value retard -25
Vtek
Post by Vtek »
Hi, how what is the proccess of getting an ecu into the software? Do i just request it here? Or is this forum only for requesting features?
The car is a Honda Civic 1.5t mt6 2017 and the ecu number is:
37820-6N0-G13
J780-300883
Bain
Post by Bain »
PLEASE can we get flexfuel tables for FK2, , , ,
P L E A S E
turboroe
Post by turboroe »
Please add an easy way to change between stock flash and hondata flash, like pressing some button combination in the steering wheel.
Currently I have to reflash my ECU once every 2 weeks to change between stock and +6psi. A simple way to do this without reflashing would change my whole experience.
Background:
I travel a lot and I am strugling with Hondata because Premium gas is only available in major cities in Brazil, and last time I made a trip on regular gas with +3 basemap I got crazy high knock count (like 300 and my knock control was above 100% all the time, so premium is only way to go with hondata here).
So it would be awesome to have an easy toggle between stock flash and, say, +6 psi map, without having to reflash every single time.
If a quick toggle isn´t possible, please allow a quicker way of toggling this with hondata plugged in. If it took like 20 seconds instead of the 5 minutes of a ful reflash, it would already greatly help because then I can flash while I get my tank filled.
Vtek
Post by Vtek »
Anyone from hondata here?
typer86
Post by typer86 »
Contact the team via email: support@hondata.com
Chero650
Post by Chero650 »
Anti lag for Tl, my car does not build any boost during launch
Syntek
Post by Syntek »
Is it possible to add a feature to where you're able to put the car in maintenance mode and be able to release the electronic parking brake for the 2016+ civics?
Vtek
Post by Vtek »
Any chance the traction control will be implemented on fk2 model type Rs in the forseeable future? Or is this just not possible because of hardware limitations
zaneliss
Post by zaneliss »
When will support for the 2021 Civic 1.5T be added?
They use the same ECU as the 2020 as far as I know.
datroe
Post by datroe »
Auto blip on downshifts.
KT7788
Post by KT7788 »
Fk2
Antilag feature
Allow adjustment of launch control
I do not believe the FK2 has a gear position sensor.
KT7788
Post by KT7788 »
FK2
how about these ?
Anti lag feature
