K20A type R/2005 rsx
Russbus
Post by Russbus »
So my car is a 2005 rsx I just swapped a k20A type r into my car, I have hondata Kpro 4 with the PRB ecu and adapter harness for the 05-06, also using the 2005 rsx engine harness.
Whenever I start up the car the RPM's are reading on the MPH side of the cluster and the RPM side is reading the MPH so it is reversed, I was wondering what can I do to fix that?
Also the temp gauge is not working.
Re: K20A type R/2005 rsx
What is the serial number that is on the K-Pro board inside the ECU?
What is the serial number that is on the white ECU plug inside the ECU as well?
Russbus
Post by Russbus »
Kpro board number is 55856
The white plug is 37820-prb-305 2054-100395 OL12
Russbus
Post by Russbus »
Check to see if the wires in the stock harness for the VSS out from the ECU and the Tach signal have been swapped.
Russbus
Post by Russbus »
That's exactly what it was I swapped the vss and rpm wires on the back of the cluster, now it works like a dream thank you so much for the help you are awsome. 🤘👍😎
BrianJewell1988
Post by BrianJewell1988 »
I literally just did this exact swap. Willing to bet you swapped the VSS and Tach wiring as it isn't THAT hard to do lol
1990 R32 GTR:Nitto 3.2L,7675 G2 SM,PPG,Hypertune,ARC,Nismo&other bankrupt-esque brands 1081AWHP@44psi on E98
2005 RSX Type S:DC5R K20A,Ported RBC/70mmTB,Injen CAI,GearX 1-4,Quaife 2 way,5.06 Gears,TL-S Brembo's, Wilwood Rear BBK,Fortune Auto 510's,etc
BrianJewell1988
Sorry I missed Spunksters reply.
Russbus
Post by Russbus »
Now trying to figure out my idle, I have a brand new iacv and everything is working fine just the idle is sitting around 964 rpm when engine is warm, how do i get it to idle around 750 to 800 i tried the idle relearn process but still no luck any ideas?
Russbus
Post by Russbus »
I tried to mess around with the duty valve cycle too but sounds like it runs rough if you move it all the way to the left, right now I have it about 3 click Mark's from the middle to the left.
Russbus
Post by Russbus »
No vaccume leaks either
Russbus
Post by Russbus »
The idle speed jumped up alittle
With the idle controller unplugged, what does it idle at?
Russbus
Post by Russbus »
I will double check when I get home but I believe around 1,500 rpm
If that is the case, then the throttle body need to be adjusted so that it idles lower.
