Ignition +6psi EU model
Civic 2016+ 1.5 Turbo
topcatdk
Post by topcatdk »
Hi
My ignition is jumping a lot up and down under full throttle.
I'm using 100 octane and +6psi calibration.
Also tried with +3psi, same problem.
No problem in stock mode.
Any ideas?
Re: Ignition +6psi EU model
Please post the datalog so we can see the knock retard.
topcatdk
Post by topcatdk »
Here you go :)
You are using fairly old software - I would update that first.
There's a lot of knock retard and the knock control is high. Seems more like 95 octane than 100 octane.
topcatdk
Post by topcatdk »
Hi
I'll try updating.
And if that not changes anything then use Shell V power instead of normal 100 octane.
topcatdk
Post by topcatdk »
Software upgraded to latest non-beta and Shell v-power 100 octane.
Fuel tank was as low as it could be before refueling, and datalog was made after 1/2 tank of the new fuel.
topcatdk
Post by topcatdk »
Dyno if that can be useful...
Have you disabled the artificial knock? (under modifications).
topcatdk
Post by topcatdk »
No, I Guess I should do that? 🤪
Yes. That probably is cause of the the knock control rise.
topcatdk
Post by topcatdk »
That didn't change much.
Does it take some time to take effect?
Yes it did - the knock control is much lower now.
topcatdk
Post by topcatdk »
But the ignition * is still going from -5 to +5 under full load?
Is that okay?
With standard calibration its almost flat.
