New cpr kit issues
Hondata CPR (Coil Pack Retrofit) support
Boostboy89
Re: New cpr kit issues
Post by Boostboy89 »
It didn’t have q37 so I had to take that board and put it in my ecu finally got the usb to read (port on laptop was bad) loaded my tune with the three boxes checked in smanager went to crank the car and same issue. I still haven’t tried A21 on the jumper harness and don’t see it changing anything seeing A21&A22 are the same essentially I suppose I could try and get another ecu with q37 in there or?
Boostboy89
Alright, I also tried A21 and it didn’t work. I also connected A21 and A22 with the ignition wire and that didn’t work either
Send an email to support<at>Hondata.com with the following and I will issue an RMA and give you further
instructions:
Name:
Address:
Phone:
Email:
Serial#:
Description of problem:
Include a link to this thread.
