P003A and P2565
FlashPro questions & answers specific to the 2008+ Accord, Americas and international
CirnoTV
P003A and P2565
Post by CirnoTV »
Hello there! I have a type r turbo with the type r turbo tune on hondata and under certain conditions like cruising at highway speeds, going into boost and then cruising and even sometimes at idle I'm getting error codes p003a and p2565. I can clear the codes and they may not come back for days or weeks and after code clearing the car runs perfect. I'm wondering if I need to replace my wastegate actuator or if this could be tune related. Thanks in advance!
Re: P003A and P2565
P003A indicates that the wastegate is not correctly adjusted. P2565 indicates an open circuit on the wastegate position sensor. It could be either of those two problems.
