Requesting a B20V basemap
anonymous408
Re: Requesting a B20V basemap
Post by anonymous408 »
CalibratEd wrote: Wed Jun 30, 2021 7:43 pm Load the tune and datalog the car normal driving. I smoothed out the map to have a base to work with.
-Ed
Cool thanks! Alright let me try it out. Should I stop-n-go traffic? WOT perhaps?
CalibratEd
Post by CalibratEd »
anonymous408 wrote: Thu Jul 01, 2021 11:13 am
-Ed
Stop and go driving for now. I want to asses how the fueling is doing.
-Ed
Instagram: calibrated.tuning
anonymous408
I tried it out just now. I had to adjust the IAC to get it up for the first time. Initially it wouldnt continue to run once I started it. Then I removed the FPR vacuum line then started again and it idled fine. After idle is fine I plugged the vacuum hose back in and went for a drive.
After shifting gears and about to come to a stop I press in the clutch then it died out. Only way to start it up is to press on the gas a little to give it more air and off I go.
You can check out the datalog file here. Thanks for looking into it!
anonymous408
anonymous408 wrote: Thu Jul 01, 2021 12:57 pm I tried it out just now. I had to adjust the IAC to get it up for the first time. Initially it wouldnt continue to run once I started it. Then I removed the FPR vacuum line then started again and it idled fine. After idle is fine I plugged the vacuum hose back in and went for a drive.
Oh and AFR does go from 15ish to around 14.7, hiccup here and there but it managed to come down between those two numbers.
CalibratEd
I am cleaning up the fuel so it might run a little sluggish for now. Load the new tune and create another normal driving log. Try to get higher in the RPM with out going WOT.
-Ed
anonymous408
CalibratEd wrote: Thu Jul 01, 2021 7:24 pm I am cleaning up the fuel so it might run a little sluggish for now. Load the new tune and create another normal driving log. Try to get higher in the RPM with out going WOT.
-Ed
It feels more sluggish. Died on the road couple of times when clutch was pressed in. Runs 17sh AFR. Heres what I have for the datalog.
anonymous408
anonymous408 wrote: Thu Jul 01, 2021 9:18 pm
-Ed
Okay I tried to fix the idle stop screw and now its idling at around 14ish, not the previous 17sh I mentioned. Too late to test drive it now but I will tomorrow. I just hope I dont die again lol.
CalibratEd
I added a lot more fuel to this revision. I will trim the fuel out once we make sure the car is not leaning out on you.
-Ed
