B20b turbo datalogging questions and help
richardmichalski19
Post by richardmichalski19 »
can someone help me with this datalog it was running ruff and dien out and kept on throwing code 9 and i just replace the distributor
and still pops the code 9
gsr head type r intake cam
1000cc precision injectors
victor x intake
bwr ram horn turbo manifold
precision t3t4 turbo
tial waste gate 6lbs
tial bov
unleaded fuel
3 inch exhaust all the way back
aem wide band
mac turbo selnoid
hondata s300 v2 de the car is dumping way to much fuel and running ruff.
Re: B20b turbo datalogging questions and help
You need to resolve the CYP error. It is either the wiring, distributor, or the ECU is damaged. You should try your ECU in a known working vehicle.
richardmichalski19
i got the code to go away now im reading 15 vaccum at idle and its dumping fuel pretty good trying figure out to adjust the fuel map!
richardmichalski19
im trying to get my b20vturbo to be safe to drive to the tuner any one can get me a base map for my set up i attached my data log
tell me what u think i should do
richardmichalski19
here is another one
richardmichalski19
not sure what im doin yet learning as i go inputplease
richardmichalski19
WELL THIS MAKES THE CAR RUN
richardmichalski19
CAN SOME ONE LOOK AT THIS AND TELL ME WHY THE CAR IS DUMPING SO MUCH FUEL AND WHY MY VACUUM IS AT 20 AT IDLE
CalibratEd
Post by CalibratEd »
Have you entered the proper data for the injectors and MAP sensor? If so this is not a bad start. You will have to lean out the fuel table. Make sure you do not apply changes during warm up. I would also deactivate the boost solenoid for now. Make sure the car has reached operating temperature.
-Ed
Instagram: calibrated.tuning
richardmichalski19
here is the last upload that i have still dumping fuel please help me out ed
richardmichalski19
this is the datalog warmed up let me know what you all think
richardmichalski19
most recent datalog was running but ruunig ruff and rich i think that the injectors i have are 1000cc precision i am stuck please some one help me with this issue look at the graph at idle when i rev it up a lil it wants to stall after i give it fuel.
CalibratEd
Richard,
Create another datalog after the coolant temp has reached above 170F. The car seems to be running very rich but I only recommend making changes after it has reached above 170F due to start up enrichment.
-Ed
richardmichalski19
ok i will get it to the operating temps and will do my best how long should the data log be ?
richardmichalski19
here is last nights warm up and idle run data log she was surging a lil and dumping lots of fuel still can figure out why
