Sending Analog Inputs to Digital Dash via Bluetooth
carloverx
Post by carloverx »
Hi,
My digital dash setup (An Android tablet running Real Dash) seems to successfully receive all data from my KProv4 except my PLX AFR, and my Autometer oil pressure sensor (both of which run into my KproV4 Analog Inputs 0 and 1).
Am I missing something, or does the KPro really not send analog input data via Bluetooth? In which case, is this information documented somewhere in Hondata's Kpro help guide?
If this is the case, am I stuck running physical gauges for all Analog Input based data?
Thanks!
Re: Sending Analog Inputs to Digital Dash via Bluetooth
It cannot see data on the analog inputs of the K-Pro in the App.
rhy
Post by rhy »
Same issue here. Analog input data shows up fine in KManager, but not in the IOS app, even though the analog input channels are already pre-populated in the app.
Is this a feature that might be coming soon?
There are no plans for this as the data cannot be sent by Bluetooth
carloverx
Post by carloverx »
Spunkster wrote: Tue Aug 10, 2021 10:48 am It cannot see data on the analog inputs of the K-Pro in the App.
Is there documentation and or a rule of thumb regarding what data the KPro can send via Bluetooth?
Only inputs data that would be readable by a normal scan tool.
Jakermac
Post by Jakermac »
Do any of the aux inputs (analog or digital) get sent by CAN to be seen/read on a digital dash such as PowerTune?
Details on what can be sent via CAN can be found in the help file: http://www.hondata.com/help/kmanager/can_output.htm
Jakermac
Post by Jakermac »
Guess I could have looked that up myself. Note to self: check the help files before asking for help!
