FlashProManager 3.8.1
FlashPro Manager software
540999115@qq.com
Re: FlashProManager 3.8.1
Post by 540999115@qq.com »
Hondata What emissions sticker?you mean the sticker on the ECU?all text are 37820-5AF-CH1,L190-101018,JCE,KEIHIN,KDG CN,Y1P.
PS:The emission of my car is 'China stage VI b vehicle emission standards'.But I had replaced a high flow exhaust and removed the GPF.
I mean the FlashProManager datalogging,software version is 3.8.1,I use a laptop.
Not only the datalogging.When push the F10 button,the number in the tabs and display window jumps very slow.The situation may like alejandroads123 says 'choppy'....eh..the numbers ,the positions in the all tabs..just...not smooth,discontinuous.
furthermore:
1.In advanced graphs,the X Y axis values could not be displayed,or only displayed 1 or 2 number.When I tuned the AFM,X axis is AFM.v,Y axis is S.TRIM,it is not very precise.Can we customize the axis sep and range?
2.In graph function,if the logging time is long,1-2minutes,the line chart will be crowded together.Is it possible to set a function button to swap 'all logged data in one screen' adn 'swipe left and right to view data'?
alejandroads123
Post by alejandroads123 »
Ok at least I’m not crazy , I’m not the only one with issues after this update .
@Doug I will send you the s/n trough flashpro manager.
I hope you can help me tomorrow, I need to finish this car .
gcapraz
Post by gcapraz »
Hi Hondata,
I have similar same issues like slow response multimedia app and it does not shows cvt temp as well.
I also have some problem when installing new version into my computer (i installed it)
i using flashpro to update new software into my car. this time flashpro acting so weird. I got keyless start engine button. when the updating finish, generally i press button 3 seconds for turn off the ignition. but this time when i press it, it closed without waiting.
Something different then the other versions.
alejandroads123
Ok I just sent the feedback regarding the serial number .
540999115@qq.com: If you are asking for new features please start a new thread.
gcapraz: Please provide details.
alejandroads123: Uploaded your calibration into a FK8 without any problems. The datalog was ok too. I suggest that you disable live tuning and re-upload.
alejandroads123
Ok I will try that , and regarding the head unit display gauges lag , there is anything we could do for improve that ?
alejandroads123
I re uploaded the calibration with love tuning disable , I cleared all the memory in love tuning .
Same thing , I timed a datalog for 8 minutes and the log just recorded chopped , and 4 minutes and a half . Is like flashpro device is working at very slow refresh rate . Head unit app doing the same .
The datalog you sent with the feedback looks ok, so I wonder how you did that.
When datalogging stops what do the lights on the FlashPro do?
alejandroads123
Is no way you can know if the datalog is correct , you can see the data recorded but not what I actually did, for example the last datalog you saw there there is no record of 3 gear pull that I did on 3 times , and that is because what is recorded is half of the time I drove . The other information I can aport is for example if I hold the accelerator at 2000 rpm it shows like I did at 1000 and something like a half , also I hold them throttle pedal for 5 seconds and it does shows like I holding for 2 aprox .
The problem is not the calibration, or the flashpro manager is something went wrong in the flashpro device after the update.
When you start dataloggin the yellow led on flashpro device blinks slower than it used to be . But it keep blinking until you push the datalog button again for stop dataloggin. Other information I can aport is when you push the button is not responsive as it was before . I need to push it like 2 times for make the datalog to stop .
alejandroads123
Haha sorry my apologies I just read my previous message and I posted “love “ tuning what I meant was “live “
janemar
Post by janemar »
10th/11th gen Civic CVT Temp
We've added the CVT temperature to the list of sensors for the 2016-2021 and 2022+ Civic CVT. Note that you will need to update your dash app to V1.6.0.0 or greater if you wish to display the temperature on the radio/navi.
[/quote]
Can you give me the previous dash app version? Any download link?
Dash app is crashing everytime I connect my FP via BT.
2017 1.5T
Poco X3 NFC
MIUI 12.5.1
Using 3.7.9 software
Why are you using 3.7.9.0?
gcapraz
Post by gcapraz »
Dear Hondata,
1-) There is an update for cvt temp sensor but there ıs not cvt temp on sensor list. Pls check the little datalog which is in the attachment.
2-) For dash app, Its acting so slowly so weird and it has got cvt temp area but its not showing it. I guess flashpro device not sharing cvt temp data. i could not find it on sensor list
3-) i also want to use options when the changing gear on cvt not to reduce ignition. I know its bad effect for cvt but only for option who wants to use that setting for their car. İt should need to upgrade cvt oil cooler for users.
Thank you, I can see that the CVT temperature was not enabled for your vehicle. I will make a software release today and post the link here for you to try out.
gcapraz
Post by gcapraz »
Dear Hondata,
I upload the new software. it works fine as before. cvt temp works fine.
By the way i m waiting support for 4 bar map sensor options.
Thanks for your support.
