S300 into P72 JDM
stingg
S300 into P72 JDM
Post by stingg »
oh Gods of Hondata.
Case modification aside.
Please help me and give me some hint on the connection part. Attached is the pics of the P72 please feel free to draw on it and comment. Thank you.
Your best bet would be to contact Locash racing as I believe they may offfer some kind of trade for your JDM ECU so that you can get a US ecu to use the s300.
stingg
Post by stingg »
Unfortunately I'm not in US. How about P30 ECU? I know where the eprom pin goes. But anyone know where the 4 pin goes????
We do not recommend trying to use the s300 in a JDM ECU....yes it may work, but it will not fit preoprly, you will have to modify the s300 and many features will not work since the ecu does not have all the circuitry.
Contact Locash and he can probably arrange some type of swap from the JDM ECU to a US ecu.
stingg
Post by stingg »
I've found 5 pin CN2 to be somewhere up left of the pics. Can I solder the shortest ribbon cable and follow the sequence 1-4 and connect it to Hondata?
Mura
Where are you from?
Post by Mura »
we have an experience of setting-up of S300 to JDM's ECu.
We could send you the pictures.
No dreams, just POWER.
kesnut
Post by kesnut »
^^^^ please do....
stingg
Post by stingg »
pleaseeeeeeee.....
Dee
Post by Dee »
I just upgraded from a JDM P72 S200B to an S300. Your best option is the USDM ECU because you will have to relocate the daughterboard and hack up the middle brace in order to make the S300 fit correctly in a JDM ECU
JDM P30's also pose fitmet problems. Yes, I own one of those too!
I am in Japan and I got my USDM P72 from Joe at Locash racing. They even istalled my S300 prep kit.
