Which donor ECU for 2006 Acura RSX type S Kpro?
jeremy85
Post by jeremy85 »
I know I cant use my stock ECU to add Kpro, so I need a donor.
I'm trying to find a 02-04 RSX Manual trans ECU for a donor, they are hard to come by these days and I'm wondering which others I may use for a donor.
As I understand, it can only be a manual trans ECU, not a automatic, correct?
Base or type S, correct?
Also I heard I can use a 2000-2005 Civic Si(EP3) Manual ECU as a donor, correct?
Which others might I be able to use that I haven't listed?
Please only answer if you absolutely know. I want this thread to be a one stop shop for ALL the 05-06 RSX ECU donor info for future forum searches.
Thanks! -JT
Re: Which donor ECU for 2006 Acura RSX type S Kpro?
The CIvic SI cannot be used.
Only the 02-04 RSX manual ECU's can be used.
jeremy85
Post by jeremy85 »
Spunkster wrote: Mon Oct 11, 2021 11:49 am The CIvic SI cannot be used.
Awesome thanks!!
Is it possible to still use the factory immobilizer?
And do I need a TYPE S donor ECU for reverse lock out? Or will reverse lock out never work again?
The immobilizer can be used, but must be matched by a Acura dealer.
Reverse lockout can be used with either ECU, but some rewiring is need with the PND ECU.
jeremy85
Post by jeremy85 »
Spunkster wrote: Mon Oct 11, 2021 12:18 pm The immobilizer can be used, but must be matched by a Acura dealer.
Thanks so much!!
jeremy85
Post by jeremy85 »
Does it matter if its a rebuilt unit?
Or does it need to be completely virgin from the factory?
I would stay away from anything rebuilt.
