Need some opinions on my tune
I have a uk ep3 type r,current mods are:rbc,70mm tb,3in intake,plm header,3inch exhaust(no cat),can some one look at my current map tell what it need or doesn't .thanks in advance.
- CalibratEd
- Contact:
Re: Need some opinions on my tune
Providing a datalog with AFR data will better help us assist you.KingK246 wrote: Mon Feb 28, 2022 5:38 pm I have a uk ep3 type r,current mods are:rbc,70mm tb,3in intake,plm header,3inch exhaust(no cat),can some one look at my current map tell what it need or doesn't .thanks in advance.
-Ed
Instagram: calibrated.tuning
Ok no problem ,any particlar type of log? ie time,idle,on/off vtec etcCalibratEd wrote: Tue Mar 01, 2022 12:56 pmProviding a datalog with AFR data will better help us assist you.KingK246 wrote: Mon Feb 28, 2022 5:38 pm I have a uk ep3 type r,current mods are:rbc,70mm tb,3in intake,plm header,3inch exhaust(no cat),can some one look at my current map tell what it need or doesn't .thanks in advance.
-Ed
- CalibratEd
- Contact:
That depends on what you are looking for. This statement is vague "can some one look at my current map tell what it need or doesn't"KingK246 wrote: Tue Mar 01, 2022 1:13 pmOk no problem ,any particlar type of log? ie time,idle,on/off vtec etcCalibratEd wrote: Tue Mar 01, 2022 12:56 pmProviding a datalog with AFR data will better help us assist you.KingK246 wrote: Mon Feb 28, 2022 5:38 pm I have a uk ep3 type r,current mods are:rbc,70mm tb,3in intake,plm header,3inch exhaust(no cat),can some one look at my current map tell what it need or doesn't .thanks in advance.
-Ed
-Ed
How did you get on with this tune? As I have the same mods and may use it?
- CalibratEd
- Contact:
Hello,jc.EP3 wrote: Fri Apr 08, 2022 3:30 pm How did you get on with this tune? As I have the same mods and may use it?
I didn’t hear from them but if you need help start a new thread or pm me.
-Ed
