Dash lights up when Disable VSA is selected
Civic 2016+ 1.5 Turbo
jtrader
Post by jtrader »
Hey all,
After modest trial and error, I've tracked down the error lights on my dash (LKAS, Brake system, ACC, check engine) after flashing due to "Disable VSA" selected to my 2019 6MT Sport Hatch.
It's funny, there are no lights on the initial drive following the tune, but the 2nd time you start the car the lights turn on and won't go away. Very strange.
Re-flashing with Disable VSA unchecked solves the problem. Not sure if this has to do w/ the fact I don't have an Si, because there is some mention to Sport mode in the description, which obviously the Hatches don't have. Anyway, just FYI.
Thanks and Cheers!
Re: Dash lights up when Disable VSA is selected
As per the help, you can only disable VSA for vehicles which do not have VSA at all. eg 2006 Si. So for your vehicle it must stay enabled.
jtrader
Post by jtrader »
Ok, that makes sense. Pardon my ignorance, I'm still new to this, but I'm slowly learning. Thanks!!
