problem with kpro ecu not recognizing ingnition being on
voodooo
Re: problem with kpro ecu not recognizing ingnition being on
Post by voodooo »
voodooo
Post by voodooo »
voodooo
Post by voodooo »
voodooo
Post by voodooo »
voodooo
Post by voodooo »
What is the serial number on the K-Pro board inside the ECU? Who did this installation?
voodooo
Post by voodooo »
Hondata K-pro-III 12799
The ecu is installed to other people, i don't know but working perfect for more time, i have check and the ecu is istalled perfect.
best regards
Please contact Alientech about this issue:
Alientech SRL
Via dei Cordari, 1
Trino (VC) 13039 Italy
+39 0161 801
KPro installer
fabio@alientech.to
http://www.alientech.to/
voodooo
Post by voodooo »
I have contact for first, i know very well and i buy the s300 or kpro to him. Alientech to phone have reply me to answer you, because him sell only...
sracer
Post by sracer »
voodooo wrote:I have contact for first, i know very well and i buy the s300 or kpro to him. Alientech to phone have reply me to answer you, because him sell only...
hi;
have you solved the problem? i am having the same trouble with this. that's why i am asking. thank you
JDM FOOLAY
Post by JDM FOOLAY »
I'm having the same problem 97 EK hatch with k swap and doesn't give power to wire harness
JDM FOOLAY
I have PNB ECU with k pro V4 was working fine removed the engine to put stage 3 competition clutch put back everything how it was now turn on crank but won't turn plug USB to laptop giving the same problem as the guy post
