P0016 error after overrev
Garrett_si
Re: P0016 error after overrev
I could fix you issue remotly
Hi I am having the same problem too could someone help me fix this please
Any information shared about the cause and solution needs to be public.
Yes some information on this would be great as I have this problem too
I thought this site was to help people with problems not to make money off it This is what this guy private message me saying
Re: P0016 code
Delete Report Quote
Sent: Fri Jun 24, 2022 11:09 pm
Recipient: Dws24
HI, sorry for late answer.
100$ i give you the trick and picture how to fix it.
Info@precisionautocanada.com for payment by paypal
Send me an email at same adress I will snd you all info
Re: P0016 code
Delete Report Quote
Recipient: Dws24
Yes, that is the purpose of this forum - sharing information and people helping each other.
Well this guy is trying to charge for the information saying he has spent to much time and money to give the information for free and wants to charge you $100. This guy shouldn’t even be on this forum if that was me I would’ve belong to prevent someone else having to go through the same problem and costing them as much as I have spent a fortune and still haven’t got to the root of the problem.
So I suppose no one has sorted this issue out yet
any update about this problem, i have the same problem.....
parts changed timing chain, tensioner hidraulic....
recently oil pump.....
I got it sometimes when i want to hear the mhi spool sound :) If i push the gas pedal a little hard at lower rpm the ecu throws this error code.I think its because of the Turbo or wg something like that. Maybe this helps to change your focus.
maikel_1992
Fix Trick happy holidays
Type R with the famous death code ☠️ P0016. The only way to fix it is to put the new intake cam and give it welding points, so it doesn't run again. and the reason why it happens is because of an over rev. Oh for fail stick shift
sjehrenberg
So the only way found to fix this code is a new intake cam and welding points? What are welding points? And should I replace my timing chain, and tensioner?
Anyone found a better solution them replacing the intake cam?
And if not, what do you.mean by welding points please? Thx
Daniel otofuji
Hi man, can you help me? I'm from Brazil and I have a Honda FK8 recently purchased. It happens that on a track day a gear error resulted in code p0016, after which the car had reduced power and difficulty starting the engine. I found on the forum that you had a similar problem and managed to solve it, could you help me with the diagnosis?Garrettsi wrote: Tue May 12, 2020 7:20 am Did you find the issue?
I have one with over rev that give the same P0016, I change the intake cam gear, what about yours?
Tyler_hall321
What is the fix for this
