02 RSX-S JDM K24A
Austinmr2
Re: 02 RSX-S JDM K24A
Post by Austinmr2 »
Ok ill try this base map. Do you run it on open loop or close loop?
CalibratEd
Post by CalibratEd »
Austinmr2 wrote: Tue Oct 18, 2022 12:17 pm Ok ill try this base map. Do you run it on open loop or close loop?
It should be running closes loop.
-Ed
Instagram: calibrated.tuning
Austinmr2
Post by Austinmr2 »
Ok thanks
Austinmr2
Post by Austinmr2 »
My setup is
K24a jdm
Rbc cut ported
80mm ktuned
TypeS oil pump
50vtc gear
4inch intake
3 inch exhaust
Bosch 13680 o2 sensor narrowband
Kswap mr2
Ran for a year 14.7 idle. 13s WOT. 14s Cruising
Then year later it use to spike richest to leanest now its 14s idle but goes to 15-18s now. Idk whats the problem.
Using tsx base map no fuel setting been touch
CalibratEd
Austinmr2 wrote: Tue Oct 18, 2022 1:08 pm My setup is
K24a jdm
Rbc cut ported
80mm ktuned
TypeS oil pump
50vtc gear
4inch intake
3 inch exhaust
Kswap mr2
It could be a vacuum leak of some sort causing the idle to go lean or maybe your o2 sensor is going out. Have you posted a datalog and tune you are running on the forum. Also, with the basemap you are running you are not full utilizing the 50 vtc cam gear.
-Ed
Austinmr2
Post by Austinmr2 »
For the base map how do i fully use the 50 vtc? And no i havnt posted my base map
CalibratEd
Austinmr2 wrote: Tue Oct 18, 2022 3:56 pm For the base map how do i fully use the 50 vtc? And no i havnt posted my base map
The car would need to be tuned for you to utilize those tables.
- Ed
Austinmr2
Post by Austinmr2 »
Can vtc angle affect afr ? And what number of vtc angle should i put on kpro for my base map tsx with 50 vtc gear.
CalibratEd
Austinmr2 wrote: Wed Oct 19, 2022 5:01 am Can vtc angle affect afr ? And what number of vtc angle should i put on kpro for my base map tsx with 50 vtc gear.
Yes vtc angle can affect afr as every angle has a fuel table that needs to be tuned. Some angles are more efficient thus causing the afr to vary. Changing the vtc angle is not that simple. There is a whole table that needs to be blended that is composed of all vtc angles. During the tuning process you will take the best of each angle populate the vtc table.
-Ed
Austinmr2
Post by Austinmr2 »
Illl try out this map since its the same setup as mine except i got a 80mm throttle body and rbc manifold this map might be leaner
CalibratEd
Austinmr2 wrote: Thu Oct 20, 2022 3:45 am Illl try out this map since its the same setup as mine except i got a 80mm throttle body and rbc manifold this map might be leaner
Any tune file you fine online will more than likely need some adjustment as no two cars are the same.
-Ed
