Looking for a base for a k20a2 turbo please!
ben2992
Post by ben2992 »
Hey all,
Finally got my k20 turbo running and its running extremely rich! I've adjusted injector value, added the wideband and the map sensor but not really looked at anything as not upto speed with it all! Any help greatly appreciated and happily donate some beer tokens. Only really looking for a safe map, fuelling etc not caring about power until i get it on the rollers
Pulsar 3076 turbo
4 bar speed factory map sensor
Bosch ev14 980cc injectors
Sytec 340 fuel pump
AEM wideband
heat range 9 spark plugs
CalibratEd
Re: Looking for a base for a k20a2 turbo please!
Post by CalibratEd »
Not a big drinker but I will take some Coffee tokens. Post a datalog of normal driving.
-Ed
Instagram: calibrated.tuning
ben2992
Post by ben2992 »
Sounds good Ed, will get a log tomorrow -thanks!
CalibratEd
ben2992 wrote: Thu Nov 10, 2022 1:22 pm Sounds good Ed, will get a log tomorrow -thanks!
Sounds good.
-Ed
sickerthanuraverage
Post by sickerthanuraverage »
looking for a base map for a k20a2 turbo my build consists of the following
stock k20a2
ep3 lsd trans
sidewinder manifold to 6266 precision turbo
bosch 2200cc injectors
walbro 450 fuel pump -10 feed -8 return
rbc manifold with 72mm throttle body rbc is port matched
4 bar map sensor
stock tps
no o2 sensor or AFR installed yet
If someone can help me out with a base map for this set up that will be greatly appreciated a lot of base maps on here don't have a set up for 2200cc injectors. Just want something safe until I dyno the car. Really excited to start this car being that this build took me about a year to complete.
CalibratEd
sickerthanuraverage wrote: Thu Nov 24, 2022 7:46 am looking for a base map for a k20a2 turbo my build consists of the following
stock k20a2
ep3 lsd trans
4 bar map sensor
stock tps
Start your own thread or send me a Pm. I can help you out.
-Ed
