traction control with hall effect sensors which switch position
Paulcsm1
Post by Paulcsm1 »
ive just bought this traction control unit
i am using hall effect sensors
I've just checked the instructions is say switch the switch towards the outside
but this unit has a different type of switch
which is the correct position for hall effect sensors
Re: traction control with hall effect sensors which switch position
They appear to be in the outside position
Paulcsm1
Post by Paulcsm1 »
sm i correct in thinking this type of switch allows different type of sensors to be used on each axle as yhere is 4 individual switches
You should use the same type of sensors for all wheels.
