2015 Civic Si Tune Needed!!!!
fttdsprtssdn
Post by fttdsprtssdn »
Hello Honda Fam,
So i have a 2015 Civic si sedan with stock intake box (has hps intake hose), Full Race ... DP, and buddy club spec 2 exhaust. Im currently running the base map "short ram intake, cat delete, cat back exhaust" tune. Im needing a custom tune if anyone can help. I did a 35min data log, but wouldnt let me attach the file.
Please Help.
CalibratEd
Re: 2015 Civic Si Tune Needed!!!!
Post by CalibratEd »
fttdsprtssdn wrote: Sat Feb 25, 2023 3:57 pm Hello Honda Fam,
Please Help.
Are you looking for something to make sure the car is running safe or are you looking for a full Etune service?
-Ed
Instagram: calibrated.tuning
fttdsprtssdn
CalibratEd wrote: Sun Feb 26, 2023 11:11 am
Please Help.
-Ed
Something to make sure the car is runing safe and to get the best preformance out of it with those mods. But not like a race tune or anything. Right now its running a little rough and im getting the p0171 code. .system too lean
CalibratEd
fttdsprtssdn wrote: Sun Feb 26, 2023 11:17 am
Please Help.
-Ed
I can help make sure the car is running safe. Getting the best performance out of the mods would be a Full Etune.
-Ed
fttdsprtssdn
CalibratEd wrote: Sun Feb 26, 2023 1:24 pm
-Ed
-Ed
Yeah thats all i really need right now. Dont want to be running lean and blow the pistons. How can i upload the datalog file? Do i need to zip it?
CalibratEd
Yes, upload the calibration file along with the datalog.
-Ed
fttdsprtssdn
Here Are the files
fttdsprtssdn
it still wont let me upload the data log tho
fttdsprtssdn
How do i get the data log small enough to upload?
CalibratEd
fttdsprtssdn wrote: Sun Feb 26, 2023 2:41 pm How do i get the data log small enough to upload?
You can cut the log or zip it.
-Ed
fttdsprtssdn
Ok i cut the 35min data log down to 20min and it let me upload it. Here it is
CalibratEd
You are running lean to the point that the trims as maxed. I made general fuel changes. Load the file and create a similar datalog.
-Ed
fttdsprtssdn
Thank you, ok i wil try this and create another datalog this evening
fttdsprtssdn
CalibratEd wrote: Sun Feb 26, 2023 7:46 pm You are running lean to the point that the trims as maxed. I made general fuel changes. Load the file and create a similar datalog.
-Ed
So the original map i sent you i forgot to disable the secondary O2 so i did that to the file you sent and uploaded it to my civic. I aslo put it back on here so you can use it for the adjustments along with the new data log.
fttdsprtssdn
Hello CalibratEd,
Just wondering if you had a chance to look at the datalog?
