Stumbles then shuts down. Won't restart until cold.
AngryScottish
Post by AngryScottish »
Vehicle: Noble M400
Kpro Serial: 47206
Software: V4.5.4
ECU: 37820-PPA-A07; 2828-106215 OF15
Kmanager: V4.5.4
Fuel: E85, sensor shows E78.
Issue:
Engine will idle for 30+ minutes, no problem.
If I drive the car, I can get maybe 15-20mins of run time before the car begins to hesitate at part throttle. Will stall coming to a stop. Won't start back up for ~30 minutes. If I let it cool down completely, works like nothing happened for another 15-20mins.
Datalogging shows nothing that would point to the issue.
What was checked:
- Fuel pump replaced
- verified getting correct fuel pressure
- New coilpacks, verified spark when engine won't restart.
- Wideband replaced
- Cleaned injectors and verified injectors were working when engine won't start
- Swapped relays around to see if car would start, nothing.
- Checked Crank sensor for voltage and 5v, both pass.
- Swapped maps, nothing
- Disabled Closed Loop, running in Open Loop, helped for a little, then would still fail.
What else could it possibly be? Why would the engine not want to stay running after being driven, but work without issue idling?
Re: Stumbles then shuts down. Won't restart until cold.
It looks like it is running cold in the datalog as it is not going past 138F. I do not know if that is part of the problem, but it should get up to an operating temp of at least 180F.
MondeCruel
Post by MondeCruel »
Are you sure yours 1300cc injectors dead time are correctly registred under "fuel injectors" ?
TTR
Post by TTR »
Are you using DW 1300cc injectors?
AngryScottish
Spunkster wrote: Tue Mar 14, 2023 11:28 am It looks like it is running cold in the datalog as it is not going past 138F. I do not know if that is part of the problem, but it should get up to an operating temp of at least 180F.
It's been 40-50F out here, and car has a lot of coolant.
Also, to be clear, this only started happening in the past 8 months. I don't drive the car that frequently, but it started happening randomly and without any real warning.
Injectors are actually ID1300s.
MondeCruel wrote: Tue Mar 14, 2023 12:46 pm Are you sure yours 1300cc injectors dead time are correctly registred under "fuel injectors" ?
That I can't verify. I can only assume they were when installed. I went from DW1300s to ID1300s.
I replaced them back in 2020, and never had an issue with stalling until middle of 2022.
TTR
Post by TTR »
Use the ID dead times for your fuel pressure that are posted on their website to rule it out. I doubt they are the same.
AngryScottish
TTR wrote: Wed Mar 15, 2023 6:16 am Use the ID dead times for your fuel pressure that are posted on their website to rule it out. I doubt they are the same.
I'll give it a shot, not sure it'll fix the issue, but at this point, I'll try anything.
AngryScottish
In case anyone comes upon this thread and wondered what the fix is:
1. I fixed the MAP sensor wires. they were quite loose. This solved the issue with no restart
2. Fuel injectors kept getting dirty/clogged. Cleaning the injectors fixed the stumble, but it would come back. Added a filter on the feed line to the injectors. Fixed the stumbling for a few years now
