Hey guys! New to the world of kpro here..
Was wondering if youbguys can help me out or not..
So I have a jdm k24a 3lobe and was wondering if some has a base map similar to my set up.. I'm about to swap my motor in and I just uploaded the k24 map (in other) but the map is not even close to what I have, would that still be okay?
So for parts list I have.
K24a
Kpro V4
Rbc intake manifold
Hybrid - fuel rail
Rsx type s - oil pump
Rsx type s - 50° VTC
PLM K24 - headers
Exedy - Stage 1 Clutch
Rdx fuel injectors - 410cc
Stock ep3 Throttle Body
2.5 header back
Rsx type S Tranny
If anyone can help me out that would be amazing..
Thanks in advance!!
K24a Jdm
MondeCruel
Re: K24a Jdm
Hi, most important is to have the right injectors registred in your calibration under Fuel Injectors for a good start up and then you will have to add fuel using your lambda sensor to the fuel maps to accomodate your mods!!
Re: K24a Jdm
Okay awesome! Thank you for your help!.
And all this can be done on the kpro right?!
Re: K24a Jdm
K-Pro is fully tunable. This will need to be properly tuned on the dyno.
Re: K24a Jdm
Okay awesome!
yeah i just wanna load a map as close to my setup, so i can drive it to get tuned.
MondeCruel
Re: K24a Jdm
if its just to get to the dyno dont worry load a map for k24 - fuel injectors > 410cc and choose rdx dead times, you can also calibrate your tps if you want under Throttle. And drive soft there to be safe
Re: K24a Jdm
Thank you so much!! You guys are awesome for your help!.
- CalibratEd
- Contact:
Re: K24a Jdm
You can also contact your tuner and see if they can provide you a basemap to get you to the dyno.
-Ed
Instagram: calibrated.tuning
