K24a EP3
captainnemo12
Re: K24a EP3
Post by captainnemo12 »
I cant make a new post . i tried the last tuned the you make pull 2 to 3rd gear and this is the graph thank you
CalibratEd
Re: K24a EP3
Post by CalibratEd »
captainnemo12 wrote: Sat Apr 29, 2023 8:33 am I cant make a new post . i tried the last tuned the you make pull 2 to 3rd gear and this is the graph thank you
What file did you use? There are several files in that thread.
- Ed
Instagram: calibrated.tuning
captainnemo12
Re: K24a EP3
The last one sir its a burgtudlerRev28 .
CalibratEd
Re: K24a EP3
captainnemo12 wrote: Sat Apr 29, 2023 9:17 am The last one sir its a burgtudlerRev28 .
Upload it here to make things easier to follow.
-Ed
captainnemo12
Re: K24a EP3
this one sir and the 2 data is the pulls using that tune thank you
captainnemo12
Re: K24a EP3
This one sir. cause i changed the injector to 410cc
CalibratEd
Re: K24a EP3
captainnemo12 wrote: Sat Apr 29, 2023 11:03 am This one sir. cause i changed the injector to 410cc
I reviewed the logs and the AFR is not that far off. There is a small area where its running a bit lean. No knock is present either.
- Ed
captainnemo12
Re: K24a EP3
Nice . But when im driving and stop the rpm is going to 2k ?
CalibratEd
Re: K24a EP3
captainnemo12 wrote: Wed May 03, 2023 2:21 pm Nice . But when im driving and stop the rpm is going to 2k ?
Check for vacuum leaks.
-Ed
captainnemo12
Re: K24a EP3
Thank you sir
CalibratEd
Re: K24a EP3
captainnemo12 wrote: Thu May 04, 2023 5:40 pm Thank you sir
No problem.
-Ed
tlikethedrink
Re: K24a EP3
Post by tlikethedrink »
ImageUpdate:
My clutch is now broken in.
I have the skunk2 rep ported. Paired it with a 72mm Ktuned Throttle Body. Now running a 3” Hybrid Racing intake.
I want to move forward with the 50* VTC and 3” exhaust. Currently running a stock TSX Kal still. I just want to make sure it’s not running lean for now.
Can I upload an idle and start from there? Or normal driving ok?
Mods:
K24a stock 25* VTC
310cc injectors
Skunk style IM
72mm TB
3” CAI
PLM Header
2.5 exhaust with resonator and muffler
CalibratEd
Re: K24a EP3
Post the log and I can take a look at it. If you want to run the 50 Vtc you’re going to have to load a calibration that runs the 50vtc or get a custom tune. The stock tsx calibration is not setup to run the 50vtc.
-Ed
tlikethedrink
Re: K24a EP3
Will do!
I’ll try this afternoon. Idle first or normal drive?
CalibratEd
Re: K24a EP3
Idle and normal driving will work.
-Ed
