Idle drops when parking
Stevieh6
Post by Stevieh6 »
Hi,
So when I'm parking or doing a 3 point turn my idle drops really low, I've actually had it cut out on me a couple of times.
Is there an option to compensate for the power steering draw in these situations?
Re: Idle drops when parking
What vehicle is this in?
Stevieh6
Post by Stevieh6 »
Integra Dc5 type R
Stevieh6
Post by Stevieh6 »
Idle control valve has been removed and that option is ticked on the ecu calibration
Why was the idle control valve removed?
Stevieh6
Post by Stevieh6 »
I don't know. Apparently it's a common mods cause the stock ICV is a bit temperamental
If you don't want it to have the issues you are complaining of, then you need to install an idle controller so that it can compensate as needed.
