Hi, I'm new to the group. i recently got a 2015 Si. Stock execpt I installed a KN Cold Air Intake and got a FlashPRo
I uploaded the MAF tune.
here is the datalog and config. I just a short cruise at 90 kmh in 6 followed by an idle and a 3rd gear short pull.....
thank you
Civic 2015 Si KN intake tune
DannGerous667
- CalibratEd
- Contact:
Re: Civic 2015 Si KN intake tune
These cars tend to do better running speed density tunes once you upgrade the intake.
Are you experiencing anything in particular?
I will take a look at the log once I’m at my computer.
-Ed
-Ed
Instagram: calibrated.tuning
DannGerous667
Hi, thank you for fast reply
Here is some other datalogs from the same calibration.
what do you mean by speed density tune ? I don't see anything like this in the tune list. I search the vault for my calibration but the only tune listed won't onpen and flashpro manager says it seems corrupt.
KN cold air intake, exhaust stock,
- CalibratEd
- Contact:
Speed density just means the car is using the MAP sensor rather than the MAF sensor.
-Ed
-Ed
DannGerous667
ok, so which tune should I start with ? Hondata reflash ? There is another tune listed for a PRL intake...
please point me in the right direction ...
thank you
thank you
- CalibratEd
- Contact:
The calibration file you posted is not bad fuel wise. The fuel trims are ok. There is knock. I will make adjustments when I have down time and post the file.
-Ed
-Ed
