k24a2 type s oil pump 50 degree vtc gt3582r turbo 1000cc injectors help tuning!
jayboostedrsx
Post by jayboostedrsx »
I need help finishing tuning my car. i'm having issues with the boost controller not reacting as expected (or at least i think). the car keeps overboosting. duty cycle on the ebcs goes nuts even when i set it to fixed duty cycle 10%. I'm hoping someone can look at some logs and give me some more info. this car has been a pain in the ass to run right
datalog2.6.kdl
Ajay_TUNE 15 (1).kal
CalibratEd
Re: k24a2 type s oil pump 50 degree vtc gt3582r turbo 1000cc injectors help tuning!
Post by CalibratEd »
What kinds of boost controller are you running? Make sure you set it properly to always open or always closed.
Set the quick spool table to 1. This table must be set lower than your solenoid activation. Once you have the controller ironed out you can tune this setting. See if this works.
-Ed
Instagram: calibrated.tuning
