Help!!! No start after turn off help!!!
Devoix
Post by Devoix »
Hey I have an 08 civic si it will start when cold but anytime after it has ran at any amount of time it will not restart it has spark when it’s doing this and you can dump ether in it and it doesn’t matter it will just crank and crank… no codes no nothing I unplugged the battery, reflashed the tune and everything nothing helps what the heck is wrong ???
Devoix
Re: Help!!! No start after turn off help!!!
Post by Devoix »
Ok now it wolnt even start at all I’ve thrown different plugs at it, ether at it, im fairly sure its not the timing bc It runs when it actually starts… now its just not starting at all.
Post the calibration used and a datalog made using that calibration that shows the issue.
Devoix
Post by Devoix »
Ok so I’ll go out and turn the car on hit data log, and let it go for like 20 sec and then save and post that hang on
Devoix
Post by Devoix »
ok here ya go... i was pushing the accel trying to get it to start just so you know... lol everything else... not me besides crank...
Devoix
Post by Devoix »
Ok from what I saw it looked like it wasn’t even seeing the cam sensors ????
CalibratEd
Post by CalibratEd »
Post the calibration and datalog of it at cold start. Once its warm does it die? does it only have trouble when you restart it after it has warmed up.
-Ed
Instagram: calibrated.tuning
Devoix
Post by Devoix »
I’ll post the calibration in a sec I gotta go read the ecu and save it and I’ll post that but now, it refuses to start period :( not even cold ?? Go figure ??
CalibratEd
Sounds good.
-Ed
