Help!!! No start after turn off help!!!
Hey I have an 08 civic si it will start when cold but anytime after it has ran at any amount of time it will not restart it has spark when it’s doing this and you can dump ether in it and it doesn’t matter it will just crank and crank… no codes no nothing I unplugged the battery, reflashed the tune and everything nothing helps what the heck is wrong ???
Re: Help!!! No start after turn off help!!!
Ok now it wolnt even start at all I’ve thrown different plugs at it, ether at it, im fairly sure its not the timing bc It runs when it actually starts… now its just not starting at all.
Post the calibration used and a datalog made using that calibration that shows the issue.
Ok so I’ll go out and turn the car on hit data log, and let it go for like 20 sec and then save and post that hang on
ok here ya go... i was pushing the accel trying to get it to start just so you know... lol everything else... not me besides crank...
Ok from what I saw it looked like it wasn’t even seeing the cam sensors ????
- CalibratEd
- Contact:
Post the calibration and datalog of it at cold start. Once its warm does it die? does it only have trouble when you restart it after it has warmed up.
-Ed
-Ed
Instagram: calibrated.tuning
I’ll post the calibration in a sec I gotta go read the ecu and save it and I’ll post that but now, it refuses to start period :( not even cold ?? Go figure ??
- CalibratEd
- Contact:
