What ECU to use
Dmn.Stmb
What ECU to use
Post by Dmn.Stmb »
Hi guys I’m pretty new to this,
Just asking what ECU should I be looking for for my k24 swapped ek civic. I’ve read so many conflicting opinions, just asking if say a PNF hondata ecu will work with a 02-04 dc5(rsx) engine harness?
Thanks.
CalibratEd
Re: What ECU to use
Post by CalibratEd »
To my knowledge you can use the ECU. The only thing is if you are running a type s transmission you will not be able to use the reverse lock out. Double check if the pins are the same.
https://www.phearable.net/information/t ... grams.html
-Ed
Instagram: calibrated.tuning
