2015 civic si
Re: 2015 civic si
Here is rev 6 log. i had some surging at the start of the drive but midway through it seemed to clear up and was not noticing it at stops. although, after i turned the logging off when i parked i noticed these new, small surges happening intermittently i attached a second log that shows a few rounds of that.
Re: 2015 civic si
all surging went away when i did the hondata reflash map this is the log for that
- CalibratEd
- Contact:
Re: 2015 civic si
Post the calibration file you used for this log.dwright17 wrote: Sat Oct 14, 2023 11:01 am all surging went away when i did the hondata reflash map this is the log for that
-Ed
Instagram: calibrated.tuning
Re: 2015 civic si
here it is
- CalibratEd
- Contact:
Re: 2015 civic si
Stick to the hondata reflash as the surging is gone. No knock is present but its running lean. I adjusted the MAF.
- Ed
- Ed
Re: 2015 civic si
here it is. driving well it seems
- CalibratEd
- Contact:
Re: 2015 civic si
Adjusted the MAF a bit more. It's still running a bit lean.
- Ed
- Ed
Re: 2015 civic si
here is the log for that revision
- CalibratEd
- Contact:
Re: 2015 civic si
I made some changes to the MAF. You should be good to normal drive the car until you get a proper tune.
- Ed
- Ed
