USDM PRELUDE with:
(Apologies in advance if some info is not required)
JDM 1998 H22a 10.6:1, Skunk 2 Tuner Series stage 2 Cams, skunk2 adj. cam gears, skunk 2 valve springs and titanium retainers, supertech hi-comp intake/exhaust Valves, megan header 4-2-1; 2.5 in test pipe, 2.5 in Greddy Evo cat-back exhaust; RC 310 injectors (no resistor box); 290lph Aem fuel pump; AEM fuel rail; AEM fuel regulator; AEM (30-0300) UEGO Kit; Hybrid Fuel pressure gauge; skunk2 Pro Series intake manifold, Skunk2 Pro Series 70mm Throttle Body; AEM short Ram Intake; Rywire obd2a to Obd1 jumper; Phearable p28 ECU; TD-94U 8 pin obd1 distributor; Rywire crank position sensor relocation to Obd1 distributor. T2W4 Trans with Action stage 3 clutch and Action Lightened Flywheel. 91 Octane.
Still has AC and Pwr Strng, and Mishimoto full Alum Radiator and Mishimoto fans.
Thank you in advance.
Help with Modded JDM H22A Base Map
Re: Help with Modded JDM H22A Base Map
Hrms wrote: Mon Oct 09, 2023 5:49 pm USDM PRELUDE with:
I Uploaded The H22a base map, and the car started right up and idled normal. When I tried to drive the car around the block, there was no response from the throttle and the car sputtered and died.
I then uploaded the h22a 440cc injectors (but I have RC 310 cc injectors. I dis go into the calibration settings and changes the injector size. I tried starting the car and it wouldn’t start.
Help please.
Herms
- CalibratEd
- Contact:
Have you tried running it with a basemap? Do you have a wideband?
- Ed
- Ed
Instagram: calibrated.tuning
I have loaded the h22a base map and I have the Aem Uego 03-300 wide band. Car started right up, but that was about all it did. Any Ideas? Do I have to assign an analog wire/connection to the Uego?
Herms
- CalibratEd
- Contact:
- CalibratEd
- Contact:
Well hello. It’s been sometime since I tinkered with the S300. So the latest updates I have are as follows, Aem X-series installed and working great. As far as my parameters, all have been set to match my car. Gearing has been set to match my T2W4 trans. I don’t have secondary butterflies in my I/M; Shift light set to RPMs; vtec activation point set. Idle speed/Rpms set. For fuel injectors I am using RC 310 injs, but in the drop down box, there is only 310 for rsx and the RC’s listed are 750 or 1000. Do I just type in 310 for current injectors? Cars starts up and idles fine, but when I went for a test drive, the car would not rev past 2k rpms 1st-3rd gear. Any Ideas? I am stumped at the moment.
Herms
Have you made any progress with this?
