plm & invidia
Fa5jay
Re: plm & invidia
Post by Fa5jay »
datalog0020.fpdl
CalibratEd
Re: plm & invidia
Post by CalibratEd »
I adjusted the timing some more . I would not drive the car to hard until its properly tuned.
- Ed
Instagram: calibrated.tuning
Fa5jay
Re: plm & invidia
Post by Fa5jay »
okay got it ill go load that on and go for a drive , question , sometimes when i click datalog before im driving and then end it how come the sometimes the datalog doesnt start or show that it starts til later on in the drive
Fa5jay
Re: plm & invidia
Post by Fa5jay »
rev4.1.fpdl
so i get what youre saying now so yeah ill keep light foot til i get my intake installed , thank you
Fa5jay
Re: plm & invidia
Post by Fa5jay »
rev4.2.fpdl
this is pretty good normal log
CalibratEd
Re: plm & invidia
Reduced timing a bit more. The car is running hot. The ECT reached 200F at one point and your IATs are a little high as well. High temps can also cause knock. Create another log. What fuel are you running?
- Ed
Fa5jay
Re: plm & invidia
Post by Fa5jay »
im leaving work now ill make a dtalog , im running 93 premium i just filled up to full tank too, is the gas bad ?
should i look into aftermarket thermostats like mishimoto , hybrid racing or new oem ? or even radiators ?
CalibratEd
Re: plm & invidia
Fa5jay wrote: Thu Oct 19, 2023 2:52 pm im leaving work now ill make a dtalog , im running 93 premium i just filled up to full tank too, is the gas bad ?
What is the average temperature where you live.
-Ed
Fa5jay
Re: plm & invidia
Post by Fa5jay »
i live in maryland so right now average like 40/50 degrees
CalibratEd
Re: plm & invidia
A lower temp thermostat will help keep ECTs down. I would look into the 8th gen forum to see what others have ran. If temps rise the engine will pull timing.
A cold air intake will help keep the IATs down. Similar to the ECTs, IATs pull timing as well to prevent knock.
Knock has been present as I believe the timing is a little aggressive. Once timing is dialed in properly the IAT and ECT tables will be able to reduce timing to prevent knock properly. I only mentioned this issue because if you get tuned and you randomly feel some power loss it would be due to these high temps.
-Ed
Fa5jay
Re: plm & invidia
Post by Fa5jay »
yeah i understand what youre saying it makes sense. ill also do my doing of research as well on thermostats and maybe upgrading rad.. i just got intake in the mail so im opening it up ill get time to install tmr and/or saturday (work schedule). so as far as it seems my intake should help ?
rev5.data.fpdl
CalibratEd
Re: plm & invidia
There is only 1 count of knock. I reduced timing a bit in that area. You should be good to normal drive the car. I suggest you install the intake when you are ready for a proper tune. The MAF adjustments that I made will have to be redone to get the car running properly again but not only that once you change the intake the car should be switched to run on speed density. Reach out when you're ready.
- Ed
Fa5jay
Re: plm & invidia
Post by Fa5jay »
i’ll load that up first thing tmr morning , i’ll send the log and i’ll reach out after install because i’m money ready it’s just me waiting on all these parts , but thanks for looking out! thank you again
CalibratEd
Re: plm & invidia
Fa5jay wrote: Thu Oct 19, 2023 5:16 pm i’ll load that up first thing tmr morning , i’ll send the log and i’ll reach out after install because i’m money ready it’s just me waiting on all these parts , but thanks for looking out! thank you again
No log is needed. Sounds good. Glad i could help.
-Ed
Fa5jay
Re: plm & invidia
Post by Fa5jay »
i’m installing my intake now should only take about a hour or so , is there a base map i can run to start and bleed the coolant system ? i’m ready for the real tune as well today
