need help with a tune
CalibratEd
Re: need help with a tune
Post by CalibratEd »
Finally had time to review all of the logs.
The fuel needs to be adjusted. The car is running lean at idle and at part throttle. I see that the calibration file is named Dyno tune. Did you change parts after you got it tuned?
- Ed
Instagram: calibrated.tuning
ibarra1557
Post by ibarra1557 »
I only adjusted idle and set my af ratios also did launch control and thats it i think never touched fuel or ign
ibarra1557
so i fixed my cable running power to unit it was throwing gauge off heres new log and i changed tune name
ibarra1557
update
rg1721
Post by rg1721 »
sending this back did slight changes to fuel . when i first looked at ur first start up u was running extrem rich like 7s let me know if you still are so it can be done
ibarra1557
Just saw this I’m going to download and try it out. Will get back to you with a data log. Appreciate all the help
ibarra1557
update # 1,898,762,125,000 heres logs along with tune you revised
ibarra1557
tune and 1 more log
ibarra1557
Pic
ibarra1557
update progress tune not finished
ibarra1557
part 2 tune not yet finished
CalibratEd
ibarra1557 wrote: Wed Nov 01, 2023 10:16 pm update progress tune not finished
Are these the logs you need me to review?
-Ed
ibarra1557
Yes
CalibratEd
ibarra1557 wrote: Wed Nov 01, 2023 10:16 pm part 2 tune not yet finished
-Ed
ibarra1557
CalibratEd wrote: Thu Nov 02, 2023 5:56 pm
-Ed
Yes
