Lambda overlay bug
yaggs89
Lambda overlay bug
Post by yaggs89 »
This has to be a software bug, as the video demonstrates I change nothing and lambda overlay goes from blank to populated. Attached is my .kal and log, as I'm sure it will be requested. Using stock wideband
https://youtu.be/qbhNQDClKtQ?si=MZZ0i_D-Tl2M6Yfy
Re: Lambda overlay bug
What is the serial number on the K-Pro board inside the ECU?
The datalog appears to be corrupt that you have posted.
yaggs89
Post by yaggs89 »
I will check serial shortly. The Software version is 4.5.7 Any log on that version displays the same. If I open a previous log of an older version, it displays correctly, which leads me to believe it was a change in the last update.
yaggs89
Post by yaggs89 »
Correction - no logs are displaying correctly upon first load. I've got hundreds to choose from in the past 3 years so no way they're all corrupt
yaggs89
Post by yaggs89 »
Serial no 56338
It is because map is datalogging as 0. Will be fixed in a release tomorrow.
yaggs89
Post by yaggs89 »
very cool, thank you for the reply. as another on here has noted, when you export a datalog, the values are 0 on the rpm column. Is this all part of that same problem? Will I be able to view old datalogs no problem?
It should all be working in the next release.
yaggs89
Post by yaggs89 »
Awesome. Thanks guys!
yaggs89
Re: KManager V4.5.8
Post by yaggs89 »
Still having the lambda overlay issue. It shows as long as i do the procedure on the video but the "data" bubble on the sensors list is not filled during datalogging.
viewtopic.php?p=134937#p134937
Did you create a new datalog? If so, post it here.
yaggs89
Post by yaggs89 »
Here is the kal and datalog
Works ok.
yaggs89
Post by yaggs89 »
Does the "data" indicator work for you? It's just an annoyance that it doesn't for me as i have a custom indicator on my display that is much bigger than the rec icon (next to lightning bolt). It verifies that im data logging with a quick glance.
