Hondata S300 and AEM CD-7 troubleshoot
Hondatuner_1
Re: Hondata S300 and AEM CD-7 troubleshoot
Post by Hondatuner_1 »
39031 serial number
Hondatuner_1
Doesn’t make sense, everything is setup as instructed. Sometimes upon troubleshooting s300 parameter setting for digital input/output, set motec sdl/adl, will upload calibration file and it will cause red l.e.d light near corner to blink continuously for some reason. Ecu is very sensitive and must unplug output harness, re-insert it and will function. Furthermore, ecu does function correctly overall. Also, if can please verify proper method for cleaning ecu. Finally, please verify Hondata hz output rate update is fixed as know previously there’s been prior issue cause faulty software.
100 Hz output with 8 packets = 80 ms per packet type
Hondatuner_1
To be honest, don’t understand sent photo data. However, please need any tips or suggestions on what to do Hondata.
I checked the S300 CAN output and it looks ok. We're doing a release later today but it should not affect anything.
Hondatuner_1
Thanks Hondata for update and reply but unfortunately still no luck.
Alan
