Skunk 2 CAI Tune
amontecinos
Skunk 2 CAI Tune
Post by amontecinos »
Hi , I installed a Skunk 2 CAI on my 2014 Honda civic si. What would be a good over all tune for the car to get a a little HP out of it if not any ? Please and thank you for your help
CalibratEd
Re: Skunk 2 CAI Tune
Post by CalibratEd »
Any Hondata base map you use will need some adjustments. Start with one with mods closes to yours and dial in the fuel and timing.
- Ed
Instagram: calibrated.tuning
Durc88
Post by Durc88 »
I have the same question... 9th gen civic si skunk2 CAI... will the PRL CAI base tune work till I get my exhaust on and get a proper tune or mail tune?
Thanks in advance.
CalibratEd
Durc88 wrote: Tue Jan 16, 2024 5:08 pm I have the same question... 9th gen civic si skunk2 CAI... will the PRL CAI base tune work till I get my exhaust on and get a proper tune or mail tune?
Thanks in advance.
It should work for normal driving only once it’s dialed in. When you switch to an aftermarket intake you need to run it in speed density.
-Ed
Durc88
Post by Durc88 »
To do that I just unselect AFM and select "use speed density/ MAP" under fuel table type?
CalibratEd
Durc88 wrote: Tue Jan 16, 2024 5:34 pm To do that I just unselect AFM and select "use speed density/ MAP" under fuel table type?
Yes, that’s correct. When you do that it’s going to be a bit more work as now you have multiple fuel tables to tune. Sometimes it’s easier to find a calibration that’s already running in speed density and dial it in.
-Ed
Durc88
Post by Durc88 »
By any chance is the a base calibration you could suggest that runs in speed density? this is my first foray into hondata....
CalibratEd
Durc88 wrote: Tue Jan 16, 2024 8:34 pm By any chance is the a base calibration you could suggest that runs in speed density? this is my first foray into hondata....
If you search on the forum there might be a few floating around. Whatever base calibration you decide to run I can help you make it run safe until you get it properly tuned. Just create your own thread.
-Ed
Durc88
Post by Durc88 »
Awesome, Thank you
CalibratEd
Durc88 wrote: Fri Jan 19, 2024 9:08 am Awesome, Thank you
No problem.
- Ed
