CAN information from S300
angrysheep
Post by angrysheep »
Hello,
I am connecting an AIM MXM to an S300 via CAN + and CAN -. I have selected the KPro CAN protocol in the AIM software and have Set the output in Smanager to Motec. I am receiving RPM. TPS, ECT, IAT,.... On the analog inputs however they read 1mv only and do not change. I have AEM pressure transducers as inputs to the S300 for fuel pressure and oil pressure. I was hoping I could get that information on the AIM via the CAN. The other issue I have is with the TPS input. I can either get the PCM to rear 0% with the AIM reading 6XXXXX % or AIM reading 0% and and PCM reading 1%. Any help is appreciated.
Re: CAN information from S300
Details on the CAN output can be found in the help file at: https://hondata.com/help/smanager/can_output.htm
angrysheep
I have reviewed that information. Are you suggesting it has something to do with the AIM Side?
The S300 outputs CAN as per the above specification. That's the extent of what we control.
angrysheep
Thank you
angrysheep
Adding to this post. I was recently reviewing the datalog from the S300. The added sensors are not logging in the S300 either? I can see them on the display screen and on the sensors screen live and the values are there. In the datalog they read 0. The other weird part is that they are both configured as pressure sensors. However, in the datalog one of them shows as 0 volts and the other shows as 0 PSI. What am I missing?
Post the calibration and datalog showing the issue.
angrysheep
So now in the logs it shows PSI for both. However, they do not always record?
