2013 Civic Si Stage 1
Josey Wales
Post by Josey Wales »
Hello all. I recently bought a 2013 Civic Si which was stock except for K-Tuned SRI. I purchased an Acuity Curl Control CAI and a Flashpro. I installed the CAI, then babied it home. My plan is to get a DP with high flow cat, then eventually an intake manifold. My first flash totally transformed the car. My only concerns were the first cold start caused a brief engine rattle, the first log revealed 16 knocks on a 30 mile trip with mixed driving(although it was all mild driving). Also first gear is a little jumpy.
My first datalog looking for knocks.
datalog0000.fpdl
Thanks for looking
Josey Wales
Re: 2013 Civic Si Stage 1
Here's my Calibration file:
2013CivicSi1.01.fpcal
CalibratEd
Post by CalibratEd »
The MAF needed minor adjustments. I reduced timing where knock was present. Create another normal drive log. I want to confirm my changes took effect.
- Ed
Instagram: calibrated.tuning
Josey Wales
On it. Thanks Ed
CalibratEd
No problem.
-Ed
Josey Wales
Same drive. Only going the other direction.
CivicLogRev1.fpdl
CalibratEd
- Ed
Josey Wales
Thank you, Sir. Here ya go, Ed
CivicLogRev2.fpdl
CalibratEd
Only a few counts of knock left. Create a similar log.
- Ed
Josey Wales
I created a new log, but the file was too big. I will make another after it stops raining. I tried to highlight half of it and save, but couldn't figure out to save that portion of it
Josey Wales
Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
CalibratEd
Josey Wales wrote: Thu Apr 18, 2024 1:20 pm Zero knocks until a did a hard pull to pass a truck. Then 16 knocks in 2 seconds. Oops
Modifications I have made are to make it run safe for normal driving only. Don't drive the car hard.
To shorten the log, right click at the point where you want to cut it and select set new end the save the log.
- Ed
Josey Wales
Thank you. I'll make a note of that. Meanwhile, I made another run.
CivicLogRev3.fpdl
CalibratEd
I cleaned up a few counts of knock. Create another normal drive log.
- Ed
Josey Wales
I did have a momentarily lapse of judgement. Realized it immediately.
Make note; Datalog was done on 87 octane. Let me know if you need another log instead.
CivicLogRev4.fpdl
