Looking for a basemap K24a FBO + Cams
Broken dc5
Post by Broken dc5 »
Looking for a basemap for my k24 Rsx with the following…
Jdm K24a
6spd w lsd
Skunk 2 tuner 3 cams
Ported skunk 2 pro series manifold
Ported 74Mm Throttle body
3.5 Hybrid racing intake
440CC RC injectors
1320 headers
2.5inch Borla catback exhaust system
Just recently had the ported manifold + TB + Intake thrown on and now car surges at idle. I’m assuming it’s getting too much air as it was previously tuned on a stock RBB manifold and just a regular ole intake.
Looking to get a tune going to stabilize the car temporarily till I throw on the 3’ exhaust and some other goodies and then can proceed with a proper dyno tune
CalibratEd
Re: Looking for a basemap K24a FBO + Cams
Post by CalibratEd »
Post the calibration you are currently running with a datalog. I can look it over and give you more insight. I am not sure when you plan to get your dyno tune but you can also reach out to your tuner to see if they can provide you a base map to get you to the dyno.
- Ed
Instagram: calibrated.tuning
Broken dc5
hey man im gonna post the calibration and a quick data log. rcently installed a manifold,Throttle body, & intake and now the car is acting up im asuuming because its getting too much air
Broken dc5
heres a datalog of it surging below
CalibratEd
I suggest you double-check for vacuum leaks. This is a common issue after an intake manifold or throttle body install. Make sure you recalibrated the TPS after the new throttle body install.
- Ed
jennecat
Post by jennecat »
I'm looking for a basemap for my JDM K24 RSX with upgraded components to stabilize the idle surge caused by recent modifications, including a ported manifold, throttle body, and intake.
eggy car
