K24 3.2 cams base map/help
daviddumb
Post by daviddumb »
I have a jdm k24 rsx with a recently built head with drag cartel 3.2 cams, as well as 550cc injectors. Before that, it was FBO with a street tune from the previous owner. I've updated that same tune with the deadtimes for the larger injectors, and it currently has no problem starting up and idling, good afr, temps, etc. I'd like to either get this street tuned asap, or tuned to just be safe and reliable until a proper tune. I've been lurking these forums and others with similar set ups, and have locked the VTC to 0 degrees, but is there anything more I should do to ensure its safe? As far as I know there aren't really any base maps for aggressive cams, I just want to make sure its worry free to drive until it can get on a dyno.
CalibratEd
Re: K24 3.2 cams base map/help
Post by CalibratEd »
Post the calibration you’re running and a datalog. I can take a look at it.
-Ed
Instagram: calibrated.tuning
