FlashPro Manager software
Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Fri Oct 25, 2024 11:28 am
FlashProManager 4.3.6 (28 Oct 2024)
Firmware updated to version 249
FlashProManager 4.3.5 (25 Oct 2024)
[2017+ Si, 2022+ Si] Added CANFlex support
[2017+ Si, 2022+ Si] Fixed launch control mods
[FL5] Added 66V-J03 (part number 66V-J04)
[2015+ S660] Changed X axis to MAP for fuel and ignition tables
[2022+ Civic] Added support for 2024 model 64A-AG2 US
[2018+ Accord 1.5 MT] Added launch control parameters
Download
here
KT7788
Posts: 67 Joined: Sat Jun 06, 2020 8:44 am
Post
by KT7788 » Sat Oct 26, 2024 6:29 am
May i check if the FK2 pop n bang issue is settled ?
Posts: 24338 Joined: Fri Sep 20, 2002 5:06 pm
Post
by Spunkster » Mon Oct 28, 2024 8:58 am
It has been removed for now.
Gmoney79
Posts: 2 Joined: Sat Nov 02, 2024 10:13 pm
Post
by Gmoney79 » Sat Nov 02, 2024 10:21 pm
I updated to this version and when I plugged my Flashpro in it said it needed to be updated and also that my previous calibration was from an old versions and ask to update it so I did. After that uploaded something to my ECU. I previously had a base tune so I believe I uploaded the same thing just with the never version on the Flashpro. My ECU did all the same things as it did when I did my first tune (the base map).
hit the download button on the online tab and then hit the upload button on the flashpro tab under calibration for primary. Car seemed to drive fine and no lights. My question is did I do it right and do I have to upload each time I update my flashpro?
I new to all this and will eventually get it professionally tuned one I get my exhaust. So any advice would be appreciated.
Thank you!!
Post
by Spunkster » Mon Nov 04, 2024 10:10 am
Any time you update the software you need to open your calibration and upload it to the ECU again. It sounds like you have done it correctly.
Gmoney79
Post
by Gmoney79 » Mon Nov 11, 2024 8:33 am
Ok cool! Thank you!
bryanzeng
Posts: 1 Joined: Sat Nov 16, 2024 7:52 pm
Post
by bryanzeng » Sat Nov 16, 2024 7:55 pm
for fk8, how can i set the pop and bang stage 1 for sport mod and pop and bang stage 2 for R mod?
Post
by Spunkster » Mon Nov 18, 2024 10:10 am
You cannot have different settings for that based on the mode the car is in.
William.Y
Posts: 30 Joined: Fri Feb 14, 2020 6:08 pm
Post
by William.Y » Sun Dec 01, 2024 8:44 pm
Hi ,may I ask , is FlashPro support FL5 ECU NO. 66V-U030? If not, how to make it support?
Another FL5 , JDM version, Chassis No. start with FL5-120, can FP support it ?
Many thanks.
Post
by Spunkster » Mon Dec 02, 2024 3:28 pm
Has the ECU been jailbroken?
Probably not supported at this time. What is the ECU part number on the chassis code FL5-120?
William.Y
Post
by William.Y » Mon Dec 02, 2024 10:22 pm
66V-U030 not jailbreak yet.
Post
by Hondata » Tue Dec 03, 2024 9:47 am
Send us the file.
William.Y
Post
by William.Y » Wed Dec 04, 2024 12:18 am
can't attach the file here, where should I send ?
Post
by Spunkster » Wed Dec 04, 2024 9:55 am
send to support <at> hondata.com
William.Y
Post
by William.Y » Thu Dec 05, 2024 3:47 am
Thanks! ECU file sent. Normally, how long it take ?
