CRANK NO START
adam_bap
CRANK NO START
Post by adam_bap »
PRB V4 kpro SN: 67281 EG civic K20z3 Eng. Trans.
Fuel is at 50PSI engine cranks no problem, but DOES NOT START. the code it’s throwing is P1361. I checked timing and everything is 100%. The cam plug has continuity, fuel pressure at 50 fresh 91 oct. new coil pack/ spark plugs. Even sprayed starter fluid in the mani. Currently on z1 base map. Also this is my first swap. The ECU works on friends kswap but we are now scratching our heads.
Re: CRANK NO START
If the ECU works on a different vehicle, then you need to follow the factory service manual for troubleshooting the error code you are getting as it is most likely the cause of the issue.
adam_bap
Re: CRANK NO START
Post by adam_bap »
Can you please help with that information
Re: CRANK NO START
You can use Honda Service Express website at: https://techinfo.honda.com/rjanisis/logon.aspx
adam_bap
Re: CRANK NO START
Post by adam_bap »
Faulty Engine Harness, switched to OEM rsx harness and she fired right up
jrawdbuildz
Re: CRANK NO START
Post by jrawdbuildz »
i have this same issue and i believe it’s this dumb cheap tucked harness.
Toons1945
Re: CRANK NO START
Post by Toons1945 »
I ran into a similar issue on my K20 swap.
